No hydro. lift
gene
07-03-2003 22:56:01
Me again with no hydro. still. IT's been a while since I really worked on the problem, but I was told by an old tractor mach. to try "85/140" oil in the hydro. lift assmble. Any thoughts or comments, could this be the problem? I have looked inside and do see a little oil coming down from the top, but no turbulance in the bottom.
Thanks Gene!!!
rod
07-05-2003 04:42:42
 Re: No hydro. lift in reply to gene, 07-03-2003 22:56:01
could be lift cylinder piston leaking or seal for it or standpipe leaking at front corner. IF you take top cover off don't forget to unhook fork assembly at sides there are four bolts in cover by seat they hold lift cyl assembly on to underside of top cover there is a gasket there also one at front corner for the pipe. I have the shop manuals copied if you need any drop me an email also have ops manuals
regards
rod
