Running on two
cooter
07-03-2003 02:14:38
I have a to20 and cylinders 2 and 3 aren't hitting,does any body have any idea what could be wrong. its not the head gasket
James, UK
07-03-2003 03:09:14
 Re: running on two in reply to cooter, 07-03-2003 02:14:38
Are you sure you have the plug wires on correctly? From #1 position, in a CCW direction the leads should be 1,3,4,2 - perhaps yours are set for 1,2,4,3 by mistake?
Are you getting a good blue spark?
Any chance any of the valves are stuck - is compression good?
Also check your plugs aren't fouled if your wires have been mis-routed.
