To20 oil filter
mike
07-02-2003 18:05:09
does anyone know the correct wix or fram # for a TO20 oil filter?
Jeff
07-03-2003 06:45:35
 Re: to20 oil filter in reply to mike, 07-02-2003 18:05:09
Here is the info I found out last summer when this question came up. The TE & TO use the same oil filter as both have Z120 engines. The NAPA number and the WIC number are the same.
Jeff
In Reply to: Oil filter on te20 posted by Mike Ferguson on June 17, 2002 at 18:59:02:
Yes, NAPA sells them, although call first as it may take a day or two to get it in. It is PN: 1107 - this is a WIC filter so if you have a auto part store that sells wic's then you can go there,
Cost here was $6.59
Yes I would change the seal.
A Massy-ferg dealer also sells the filter and seal as a kit. I do not know the PN's but they should. Some one said that the oil filter seal was about $2.50. I had a kit price of about $12.00 when I called.
Jeff
Duner Wi
07-02-2003 19:21:11
Fram C 153 or Baldwin T44M.
