What Ferguson Model Do I have?
Ron Stone
06-27-2003 21:00:54
Recently I bought a ferguson tractor and was told it was a 1953 TO30. I have a problem with the carburetor that bears the name ZENITH. The carb has 2 numbers on it above the bowl that contains the small round float I need to replace. The numbers are 241-2 on the side of the housing and 61264 or 61284 on the top of the housing. The radiator has a tag that says made in coventry england.
Please advise how I can tell the difference between a TO or TO 30. Do you have any idea where I can find a serial number on this beast so I can get the correct parts for the tractor.
Thanks
Ron Stone
john(UK)
06-28-2003 07:14:05
 Re: What Ferguson Model Do I have? in reply to Ron Stone, 06-27-2003 21:00:54
From what you say you could have a TE not a TO
TE was made in UK, TO was made in Detroit
Serial number should be on a plate just in front of the steering wheel shaft, where it goes though the dash panel with the throttle lever. A TE had a Continental enine on the early ones and a Standard Motors engine on the later ones, and a TO had a Continental engine. Quick visible check is Oil filler for engine is at rear left side of engine on a Standard and at front left side on Continental. One other way to tell is the gearbox housing...on a TE its made of magnesium electron (like aluminium) on a TO its made of cast iron like the axle housings.
Ron Stone
06-28-2003 16:13:47
 Re: Re: What Ferguson Model Do I have? in reply to john(UK), 06-28-2003 07:14:05
I have looked at the area for the serial number plate and it is GONE!!! The oil filler is on the left rear of the engine and the number stamped on the engine is S102057E. I therefore believe this is a Standard Motors Engine but I still don't know the model, TE or TO 30.
Anyone have any other ideas
john(UK)
06-28-2003 16:34:42
 Re: Re: Re: What Ferguson Model Do I have? in reply to Ron Stone, 06-28-2003 16:13:47
Standard engines were not fitted to TO models only Continental engines, so its a TE
john(UK)
06-28-2003 16:39:41
 Re: Re: Re: Re: What Ferguson Model Do I have? in reply to john(UK), 06-28-2003 16:34:42
Did you check what the gearbox housing was made of like I said in my earlier mail, cast Iron for TO tractors and magnesium electron (like aluminium) if its a TE...I am pretty certain you have a TE20...serial number tells all.
Jeff OH
06-28-2003 06:58:36
Check you engine model number on the left side. If it says "Z120" then you have a 20 series tractor if "Z129" you have a 30 series.
As for a TE or a TO tractor look at the Distributer. if Delco you have a detroit made TO if it says Lucus you have an English made TE.
TE- Tractor England
TO- Tractor Overseas (i.e. USA)
Hope this helps.
cdmn
07-05-2003 20:49:50
 Re: Re: What Ferguson Model Do I have? in reply to Jeff OH, 06-28-2003 06:58:36
And in addition, there was no TE30. Am I right?
cld
Peter.U.K.
06-27-2003 22:34:21
Sounds like you have a Coventry, England built TE or TEA. There should be a plate just below and in front of the steering wheel which should bear a stamped serial number. If you can let us have that we should be able to tell you exactly what you have.
Allen Davy
05-16-2005 17:43:34
 Re: Re: What Ferguson Model Do I have? in reply to Peter.U.K., 06-27-2003 22:34:21
My father-in-law just gave me TE ferguson, the serial # TE 48791 is on the plate under the steering column. Could you possibly tell me what I have? I've just read the forum pages and read your response to another question. It hasn't been run for over a year. When it was last run it would run for awhile and then just sort of dies out like an electrical drain. Just had a mechanic look at it this evening. We both feel it is electric, he's never seen a TE before. Will I have trouble getting parts? Thanks for any info. Thanks!!!!
Nelson
06-27-2003 21:16:30
I have a 1953 TO-30. It has a Marvel Schebler carburator, not Zenith. The I.D. tag should be right in front of the steering wheel column.
