Install Head Gasket
R Austin
06-26-2003 16:24:55
When I install the head gasket on my TE20, can I use any enamel spray pain when spraying both sides of gasket before torquing down. Thanks.
James, UK
06-27-2003 02:19:52
 Re: Install Head Gasket in reply to R Austin, 06-26-2003 16:24:55
Personally, I would avoid using anything that will or could prevent proper sealing of the cylinder head gasket until after everything has been torqued down.
In some instances, it can also be a good idea to re-check the head torque on the bolts after a few hours running - just to be sure.
john(UK)
06-27-2003 10:38:45
 Re: Re: Install Head Gasket in reply to James, UK, 06-27-2003 02:19:52
Its always a good idea to check the torque settings after the engine has been run and reached working temperature. I agree with James use nothing until everything is tight.
