Transmission
delane hawkins
06-23-2003 04:41:32
on a to30 the filler plug on top of the plate where the gear shifter is located could someone tell me whayt kind of oil shuold be used in there and also the steering gear box is totallt seperate from the lower housing any help would be great.
marlowe
06-24-2003 15:18:40
 Re: transmission in reply to delane hawkins, 06-23-2003 04:41:32
in the trans. and diff.and hyd. use 90 wt MINERAL OIL or GL-1 but make sure mineral oil THE NO. FROM MF IS M1103. [don't use 90wt.gear oil]some big wal-marts sell Gl-1 in 5 gal. pails it takes 6 gal.
James, UK
06-23-2003 06:32:33
Delane, at the risk of appearing curt, if you have a search through the archives, there is a wealth of info on the topic of oil.
In short, back end and main gearbox, all one filler, 90 wt oil if your are in US or Canada, what we call SAE 40 or 15W-40 oil over here in UK.
Same oil for steering box unless it leaks, in which case fill it full of grease, or spend ages replacing the bearing seals where the drop arms come out (more info in archives). Filler for steering box is square plug pointing at driver.
