Oil pressure on a TO30?
jeff
06-22-2003 18:18:59
my father has my tractor right now,but i'm pretty sure my oil pressure reads 40 on the guage,i was looking in the archives and 40 seems really high,the guy who owned the tractor before me had the engine rebuilt,i think it reads 40 at idle as well as full throttle,the needle does go down to 0 when tractor is turned off,what should i be reading for pressure at idle and full throttle,should it be different? the tractor is a TO30 1951
Larry in Missouri
06-24-2003 08:44:53
 Re: oil pressure on a TO30? in reply to jeff, 06-22-2003 18:18:59
I've got a 1952 TO30 and rebuilt its engine, and the gauge basically pegs on startup, and then drops just a tiny bit as it warms up. I figure the gauge is pretty bad. I think it reads 10 PSI too high, which would make it running at 30 PSI - right at the relief valve value.
Larry
Ray,IN
06-22-2003 20:47:42
Since the rebuild job is an unknown, the actual oil pressure must be determined by using a known accurate gauge. The original pressure gauge is not very accurate. I do know the original oil pressure relief valve is set to 30psi max. The stock contenental engines will operate faithfully on 5psi/idling, and 15psi at WOT--assuming the correct engine oil is used. I,n told too much oil pressure does not allow the oil to absorb heat from bearings because it passes through so quickly.
James, UK
06-23-2003 03:13:09
 Re: Re: oil pressure on a TO30? in reply to Ray,IN, 06-22-2003 20:47:42
On bearings and oil pressure:
If oil passes bearings quickly (high mass flow rate in terms of mass per second or m(dot)), the temperature rise (dT) of the oil will be smaller, but the net temperature drop (the 'work' done by the oil or 'Q') will be the same or better than for oil flowing more slowly.
The reason for this is that the heat coefficient (Cp) for the oil will only allow heat to be absorbed at a given rate. Varying the rate the oil flows at will only change how hot the oil gets - slow flow, oil gets hotter (and so does bearing) - fast flow, oil stays cooler, but heat removal is better (bearing stays cooler) because of a greater temperature differential between the oil and the bearing.
Increasing oil pressure will reduce oil mass flow rate, and so will make bearings run hotter.
The engineering notation for this, is:-
Q = m(dot) x Cp x dT
In this instance, we can change m(dot), and the change in oil temperature (dT) between oil arriving at the bearing, and leaving, but Cp remains a constant, and Q must satisfy a minimum or better value if the engine is to survive.
Another way to think of it is that you can use a small nuke to boil water in a kettle in a fraction of a second, or achieve a kettle of boiling water with a cooker flame in 15 minutes. The same amount of work (temperature change) is done to the same fluid (same Cp) in each case, but the energy flow rate (the Q) has changed for the same mass.
Hope this helps.
Jimbo
07-18-2003 21:44:24
 Re: Re: Re: oil pressure on a TO30? in reply to James, UK, 06-23-2003 03:13:09
Yo, James UK,
I know this isn't the place to ask this question but it is pretty much the same as the oil pressure/heat transfer question. Please believe me this isn't making fun of your answer which makes sense, in fact should be common sense. Maybe you can shed some light on it.
For many years I've wondered whether when it is raining do you get wetter if you walk to the barn or if you run to it? I almost got divorced over this one because when I posed the question to my wife she decided I'd finally gone over the edge.
I think if you walk, you're only occupying a very small space at any given instant and will absorb only that amount of rain. If you run, you'll occupy more space in that same instant than if you walk and any rain in that space will be absorbed by your body. So, it doesn't matter whether you walk or run you'll get just as wet. Almost the same as your oil pressure/heat absorption problem. No?
I really ain't nuts it's a valid question.
Jimbo
gsdpilot
12-30-2004 09:06:27
 Re: Re: Re: Re: oil pressure on a TO30? in reply to Jimbo, 07-18-2003 21:44:24
Jimbo,
I was perusing the forum for information on oil pumps, pressure, etc for my 1951 TO-30 and came across your "Do I get wetter if I run or walk in the rain?" question. I realize that you posted this long ago but figured since I didn't see an answer I'd throw in my two cents.
This question was posed to us in college Physics. The answer, as it turned out after a fairly short derivation by the Prof, was RUN. It basically came down to an assumption of a constant rate of flow of the rain and the time spent within the flow. If I take less time, I am less wet. I've never forgotten the answer although I'm not sure I could recreate the proof. I'm sure there was at least on integral in it. So good luck, and stay drier by running.
BTW...I always walk regardless of the proof unless it's really a down pour.
gsd
Ray,IN
06-24-2003 04:39:53
Question James, You stated that "The reason for this is that the heat coefficient (Cp) for the oil will only allow heat to be absorbed at a given rate." How will faster flowing oil absorb more heat since the contact time is less? If your theory is accurate why aren't engine mfgrs. designing oil pressure to much higher standards, say 150psi?
James, UK - long post
06-25-2003 01:35:06
 Re: Re: Re: Re: oil pressure on a TO30? in reply to Ray,IN, 06-24-2003 04:39:53
OK, perhaps my example of the boiling kettle wasn't a very good one. . .
Firstly, it isn't my theory, it is a function of one of the three immutable laws of thermodynamics which go something like this:-
1. Nothing gets hot all by itself.
2. Nothing gets cold all by itself.
3. If you put something hot next to something cold, the cold thing will get hotter, and the hot thing colder, until they reach a state of equilibrium.
Also, I should have called Cp the Specific Heat Capacity, not the heat coefficient - the coffee hadn't kicked in.
To avoid a lecture in thermodynamics (probably not fun or interesting unless you are an engineer) think instead of sitting in your office on a hot day. You have a fan in front of you set to speed 2 - but you still feel hot.
Do you turn it down to speed 1 to cool down more, or up to speed 3? The exact same principle applies to nice cooling oil flowing through a bearing in an engine, but you can get to the point where the oil is flowing so fast that it (a) doesn't reach all the places it should so (b) won't absorb the heat it is required to. Similarly, if oil flow is too low, the oil does not remove the heat fast enough.
Now to answer your question on why engine manufacturers don't all use 150 psi pumps in their engines - it's a balancing act between pressure (since you want the oil to be forced through all the important parts) and flow - which you need to remove the waste heat from an engine.
It is possible to have high pressure and low flow, or high flow and low pressure, or a mixture of the two - but flow and pressure are two completely different things.
There is a rough rule of thumb that states that the flow from a pump rises as a cube of the energy needed to drive it - so doubling the flow does a lot more than double the power required, and you need 8 times more energy.
Hold that thought - and now consider installing a monster oil pump in your engine - how much power (energy) is going to be left to drive the car? A manual transmission will absorb up to 5/8ths of your rated power output - so if your oil pump takes another chunk, performance of your car or tractor will drop fast!!!!
I am running on memory here, but I think something like 30% of the calorific input (from the petrol/gasoline) to an engine is wasted as heat to oil, exhaust, water in the cooling system, and radiant heat, and another few percent is lost to driving the water pump, alternator, oil pump, mechanical fuel pump (if fitted), a/c will rob another 5bhp or so, etc.
Finally - "How will faster flowing oil absorb more heat since the contact time is less?". Yes, the unit contact time of each small 'chunk' of oil is less and each 'chunk' therefore absorbs less heat, but you have more 'chunks' of oil passing per unit time, so the net effect is the same (or better if you include heat exchange theory, where the delta T needs to be higher for more effective heat transfer).
You will just have to take my word on this - it's the way thermodynamics works - it's funny stuff, but it works - just look at the average jet engine - pure thermodynamics is giving you the power needed to lift a jumbo off the ground.
Nuff said on this, I think. Sorry for the long posting.
Jimbo
07-18-2003 22:15:11
 Re: Re: Re: Re: Re: oil pressure on a TO30? in reply to James, UK - long post, 06-25-2003 01:35:06
If you pump oil through a bearing into a sump at 15 psi for a given amout of time and then pump oil past the same bearing at 100 psi into a different sump, when you get through the 15 psi sump is going to hold a smaller amount of oil that the 100 psi sump but it will be hotter than the 100 psi sump oil. Question is: Which holds the most heat (energy), the small amout at high temp or the large amount at lower temp? They should contain the same amount of energy.
Another way to look at this...place two identical pans on two identical burners on a stove cooktop. place twice as much water in one as the other. Heat them for awhile. With calibrated thermometers in each check the temperature. Are they the same temperature? No! Does each pan contain the same amout of heat? Except for minor differences of heat loss, they should.
Jimbo
Ray,IN
06-25-2003 18:37:47
Thanks James, you make complete sense. It appears we are saying the same thing but in different ways. I'm used to reading and listening to engineering language. I'm retired from tool and die making.
James, UK
06-26-2003 03:32:14
 Re: Re: Re: Re: Re: Re: oil pressure on a TO30? in reply to Ray,IN, 06-25-2003 18:37:47
Phew! What a relief - it's that old language thing again. :-)
James, UK - PS
06-26-2003 04:30:35
 Re: Re: Re: Re: Re: Re: Re: oil pressure on a TO30 in reply to James, UK, 06-26-2003 03:32:14
Major respect to any tool and diemakers out there, some of you guys have been real artists, and it's a shame the profession ain't what it used to be.
Jeff-Oh
06-23-2003 05:59:29
Geeezzz. James. Your not an in-ga-near or nu-than are ya? :)
Unfortuantly, or fortuantly I understood everyword and James is correct.
Jeff
MA-Aero/Asto Eng.
James, UK
06-23-2003 06:23:23
 Re: Re: Re: Re: oil pressure on a TO30? in reply to Jeff-Oh, 06-23-2003 05:59:29
Guilty as charged, Your Honour, I are a injunear.
Crazy, isn't it, we spend all week playing with clean bits of metal, and relax at weekends playing with really filthy bits of metal that should have been pensioned off years ago.
Jeff-Oh
06-23-2003 09:37:33
 Re: Re: Re: Re: Re: oil pressure on a TO30? in reply to James, UK, 06-23-2003 06:23:23
It's becasue all week all we have are these compueters and paper no real hardware to play with.
Joe Truchard
06-25-2003 19:26:06
 Re: Re: Re: Re: Re: Re: oil pressure on a TO30? in reply to Jeff-Oh, 06-23-2003 09:37:33
It seems to me, another function of oil thru the bearing is principally to reduce friction, thereby heat generation. I am also an engineer, but I had some problem with flow rate theories. Matter only gains or looses heat, it does not gain cold.
Assuming, if oil moves thru the bearing faster it gains a total of more heat. It also moves thru the area in the reservoir faster giving up less heat, meaning the delta T across the bearing and the reservoir might not be greater for fast moving oil. I have a theory that may or may not be true, but up to a point, greater pressure may force greater separation or greater assurance of oil molecules separating bearing surfaces, reducing friction, therefore causing the bearing to stay cooler and wear less. I think the idea here is for two bearing surfaces to be separated by a thin film of oil. This would explain why manufacturers do not set the pump pressure at 120 psi. They set it just high enough to force a film of oil to all surfaces of a new bearing. Any thoughts on what I just said? Any bearing designers out there?
Jeremy Heim
06-26-2003 14:04:35
 Re: Re: Re: Re: Re: Re: Re: oil pressure on a TO30 in reply to Joe Truchard, 06-25-2003 19:26:06
Seems to be a lot of engineers out there with old tractors. Makes sense to me though. What other job combines people that tinker with old tractors with minds like ours and the convenience of internet in our offices.(I had to use spell check on convenience for those of you who know what I mean.)
The whole oil system thing to me is simple. Oil is used to reduce friction. We want just enough oil pressure to force oil between the bearing surfaces. Any excess pressure could be generating heat in the oil itself as it is forced through the pump and lines/channels. I'm sure the oil is involved with heat transfer, but that should be minimal compared to the engine coolant. Hopefully the oil transfers heat out through the oil pan and through the block to the water channels faster that it gains heat from the pistons and bearing surfaces. Unfortunately, my little blurb doesn't set an exact value for oil pressure. In my opinion 5 to 20psi would be adequate.
I just bought a TO-20. It has an external oil filter on the right side of the engine. Anybody know what Fram(or other) filter number I need to replace it?
Jeremy Heim
06-26-2003 14:18:26
 Re: Re: Re: Re: Re: Re: Re: Re: oil pressure on a in reply to Jeremy Heim, 06-26-2003 14:04:35
Maybe I really bought a TO-30 if the oil filter is on the side huh?
James, UK
06-27-2003 02:34:07
 Re: Re: Re: Re: Re: Re: Re: Re: Re: oil pressure o in reply to Jeremy Heim, 06-26-2003 14:18:26
Nope, it could still be a 30 - it just depends on what engine you have - Continental or Standard? If Z129 Continental, it a TO30, or if a Standard with 85mm bore dia, also a 30, but if a Z120 or Standard 80mm it's a 20.
Then again, you might have a diesel, Standard, Perkins, or other flavour.
As to what oil filter, this will be dependent on which engine you have - and the info you need will be in the archives, somewhere, along with loads of other useful stuff.
phil fenner
06-30-2003 10:56:47
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: oil pressu in reply to James, UK, 06-27-2003 02:34:07
If the filter is on the right side looking forward then I believe it is the 30 and if it is on the left side it is the TEA-20 big bore model.
