TO 30 engine knock
marc
06-18-2003 21:33:32
I appear to have a slight knock coming from the front of my engine. Can anyone clue me in to what it might be?
George
06-22-2003 04:30:49
 Re: TO 30 engine knock in reply to marc, 06-18-2003 21:33:32
Had a similar problem, suggest you make sure all plugs are firing. Pull your plug wires one at a time with the engine running. It may just need a new plug.
Crem
06-19-2003 20:52:17
I had a TO 30 that had a knock and the cause was a loose front crankshaft pulley.
Crem
06-19-2003 21:13:55
 Re: Re: TO 30 engine knock in reply to Crem, 06-19-2003 20:52:17
A knock that I had on a TO 20 was caused by a worn bore in the block for the front camshaft bearing. They don't have a pressed in bearing. I think that the knock was greatest when the engine was idling. If you suspect this, remove the rocker arm cover and while the engine is idling, push down on the top of the valve spring as it moves up and down. This pressure on the spring somehow causes the knock to become lighter. This knock should not be confused with tappet noise from excessive valve clearance.
Rusty
06-19-2003 14:47:46
I will take a wild guess. It could be a rod knocking around. Or a cam lobe knocking against a lifter. Or a rocker. Well, that is 3 shots in the dark. Good luck.
