Z-129 rocker assembly
tim
06-18-2003 16:48:26
I am currently rebuilding a ferguson to-20 with a
z129 motor.
I am looking for information regarding rocker arm
assembly. What is my best route for repairing,
rebuilding or buying a complete assembly ???
Can bushings be made for the existing rockers, if
so what clearance is required between bushing and shaft ?
Is there a good source for a shaft also ?
I have found one assembly in good shape but it does not have the oil caps just cotter pins. Will this create problems ?
Thanks.
Paul in AZ
06-22-2003 20:40:47
 Re: z-129 rocker assembly in reply to tim , 06-18-2003 16:48:26
Sparex, a tractor parts wholesaler, has new rocker arm shafts and other rocker arm parts. Find a parts distributor that has an account with Sparex and order what you need.
Duner Wi
06-19-2003 07:57:59
The way I fixed my TO 20 is probqably the worse way. I bought bushings from Motion Industries. Machined the outside to fit my rocker arms. Drilled oil holes. Dremeled oil groves and bought a new rocker shaft thru MF for $150.00 US. That can not be the best way. I don't understand about the oil caps and cotter pins. VAC Case rocker arms look to be much Fergies. The bearings are a little differant and some of them have differant out side diameter on the bearing. Good luck.
Rusty
06-19-2003 19:03:04
 Re: Re: z-129 rocker assembly in reply to Duner Wi, 06-19-2003 07:57:59
You can buy a rebuilt one for $190. I suspect they do not replace the shaft on the rebuilds.
