No power on my TO30
Tom H.
06-13-2003 07:42:39
First off this is a great site for very helpful info. Thanks.
Okay the problem is that after I had changed out my manifold, replaced connecting rod bearings, refreshing seals all over the place and replacing all ignition parts except the coil my tractor is not running up to power like it had before.
I ahve checked the timing and that seems to be okay, about 8 degrees at 7-800 rpm. The power loss come when trying to climb any hill. In neutral I can get about 2100rpms out of her but tryng to go in gear the engine won't excellerate under load. I am waiting for a carburator rebuild to come and have an idea that that may be part of the answer. The other thought is is my governor working properly. Its a 54 TO30 with the ball type governer and that I have not touched.
Any help would be great.
Tom
john(UK)
06-13-2003 10:47:10
 Re: No power on my TO30 in reply to Tom H., 06-13-2003 07:42:39
Does the governor work at all? If you watch the governor linkage as you open the throttle wide it should speed up and then the linkage should move and shut it down to its correct governed speed, if it isnt doing that you will get same effect as you are telling us. If the governor seems to be working ok have you checked the main jet adjustment of the carb?...If you say the carb needs a rebuild, possibly you need to open the main jet to compensate for any wear that allows more air in and is weakening the mixture
Tom H.
06-13-2003 11:46:01
 Re: Re: No power on my TO30 in reply to john(UK), 06-13-2003 10:47:10
John,
I did check the governor as far as when I add power in neutral it does hold the engine from over accelerating. It does seem that it won't let the engine rev when power is needed.
john(UK)
06-13-2003 14:00:06
 Re: Re: Re: No power on my TO30 in reply to Tom H., 06-13-2003 11:46:01
well you could try putting the tractor in gear (2nd)at about 1/3 throttle and start to engage the clutch with the brakes on and you should see the governor open the throttle on the carb. If it doesnt do that, try moving the lever coming out of the timing cover by hand to full throttle, if its working you should feel it pushing the throttle towards idle again and if it is, maybe its just a matter of adjustment on the rod to the carb. MIND YOUR FINGERS IN THE FAN
Tom H.
06-13-2003 16:05:20
 Re: Re: Re: Re: No power on my TO30 in reply to john(UK), 06-13-2003 14:00:06
Hi John,
I did try pushing on the throttle linkage and yes the governor pushes it back towards idle ok. So maybe it is a linkage thing or could it be the timing is off?
john(UK)
06-13-2003 16:40:41
 Re: Re: Re: Re: Re: No power on my TO30 in reply to Tom H., 06-13-2003 16:05:20
Does it open the throttle when it comes under load though? You should see it move the lever to open.
Rusty
06-13-2003 09:37:05
I would check the electrical system again and be sure it is in order.
Dan
06-13-2003 18:45:32
 Re: Re: No power on my TO30 in reply to Rusty, 06-13-2003 09:37:05
Make sure you have the plug wires on the right cylinder, if you have one crossed, you'll definitely have a power loss.
Tom H.
06-13-2003 16:06:26
Thanks I'm planning on rechecking the timing and also the carb settings.
