TO20 condensation
Mike H
06-11-2003 11:19:52
I just bought a TO20 and noticed after running it for some time(six miles to the CO-OP tire shop) that quite a bit of condensation had built up in the filler tube. I know that the tractor had been sitting outside all winter and spring. How much condensation buildup is normal there? (whitish gray gunk) I dont believe its anitfreeze..no smell and there is no exhaust smoke. Other than this the tractor runs great. thanks for any and all advice.
rod
06-11-2003 16:01:57
 Re: TO20 condensation in reply to Mike H, 06-11-2003 11:19:52
the original instructions called for oil changes after so many hours of use and I think at least sping and fall. there is a large amount of area inside the castings for condensation to form normally getting it up to hot temp by plowing or such hard work would evaporate it best advice is keep the oil changed and when you go to change it make sure it is warmed up good that is about all you can do.
regards
rod
