Identification of a TE20
Bousmanne Laure
06-10-2003 10:30:40
Hello, I have a TE20 and there isn't a plate neer the steering wheel. I suppose the serial number is on an other place on the tractor. Can you say me where the serial number of my tractor can be found? I have just the engine number: S211561E . thank you to give me a response.
BOB UK
06-17-2003 13:11:43
 Re: identification of a TE20 in reply to Bousmanne Laurent, 06-10-2003 10:30:40
You have a 1952 TED acording to my records,
Come back to me and I will help you confirm it.
BOB UK
john(UK)
06-12-2003 11:56:48
The engine serial number is for a Standard Motors engine. The serial number for the tractor should be on a plate on the dashboard where the throttle control goes through the dash just forward of the streering column, look for 4 rivets, the plate may have been painted over or four small holes, the plate may have been removed.
rod
06-10-2003 18:46:49
if that number came off the engine block from behind the dist it should be a TEA 20 if carb is zenith with 24t2 and oil filter is on left side in canister would confirm it. email me for more info
regards
rod
