TO-20?
Mechanical Bull
06-09-2003 16:54:51
I bought a tractor and over the years the serial numbers have become hard to see. I was wondering if there was a way to identify between a TO-20 and TO-30 by looks and if you could distinguish between the years of it. I am new to this area, Please help!
rod
06-09-2003 19:19:59
 Re: TO-20? in reply to Mechanical Bull, 06-09-2003 16:54:51
If the tag is still above the dash take a torch and burn the paint off it then take a lead pencil and run over the tag this should highlite the numbers the Z 129 engine was used in the TO 30 the TO 20 had Z 120 if you can find number on engine that would be a good way to tell I have all the manuals copied if you need any let me know
regards
rod
Phil (VA)
06-10-2003 06:12:44
 Re: Re: TO-20? in reply to rod, 06-09-2003 19:19:59
Also, the 30 has an external oil filter and the 20 oil filter is inside the pan.
Mechanical Bull
06-09-2003 19:31:38
Cool I'll check that out. Thanks alot Rod
