Wire gaugestarter switch
steve
06-03-2003 16:26:09
What wire gauges should i use to replace the wiring for the ignition switch coil wires + & -,gen wires,distributor wire?And i want to go back to the original starter switch but when i went to loosen the 2 nuts 1 of the batt cable studs are spinning does this mean that the switch is no good? this is the switch on top of the tranny.
Dan MO
06-03-2003 19:43:15
 Re: wire gaugestarter switch in reply to steve, 06-03-2003 16:26:09
Gauge----- amps
14----- 15
12----- 20
10----- 30
8----- 40
6----- 60
The generator will put out between 16 to 18 amps,
so 12 gauge stranded wire would be sufficient.
steve
06-03-2003 22:08:42
 Re: Re: wire gaugestarter switch in reply to Dan MO, 06-03-2003 19:43:15
thank you for the info.
Ray,IN
06-04-2003 20:11:29
 Re: Re: Re: wire gaugestarter switch in reply to steve, 06-03-2003 22:08:42
Replace the starter switch, when the stud turned the contact cut the insulation and created a short. NAPA, Carquest, and MF dealers carry them.
steve
06-05-2003 17:33:38
 Re: Re: Re: Re: wire gaugestarter switch in reply to Ray,IN, 06-04-2003 20:11:29
Thanks you M F told me the switch is $120.00 but they had a brigs & straton that was the same for $27.00?
