TO20 ELECTRICAL PROBLEM
Mike Kennedy
06-01-2003 18:57:14
Having problems keeping a charge on my battery. Just purchased the battery July of 2002 so it should still be good. I am showing a charge on the meter, but after cutting 4 acres their is not enough juice to restart if I shut her down.
Is it possible to show a charge on the meter and not be charging the battery?
I would appreciate any help or guidance on how to troubleshoot this problem. Thanks.
George
06-03-2003 07:19:02
 Re: TO20 ELECTRICAL PROBLEM in reply to Mike Kennedy, 06-01-2003 18:57:14
My battery was connected with reversed polarity at some time in its life...therefore it does not charge at all.
I can start this tractor (TO 20) many times and run it (couple hours at least) without running the battery down. I don't know how long it takes you to do the 4 acres, so maybe yours is running a lot longer than mine.
You could check the voltage across the battery. Check it with the tractor off, and then running with meter showing a charge....the voltage across the battery terminals should be a volt or so higher when being charged.
Ray,IN
06-01-2003 20:02:23
Don't accept the tractor ammeter as accurate. Use a VOM to check the voltage at about 1/2 throttle, it should read between 6.5 and 8 volts depending upon the battery condition and state of charge. Another method is to install a ammeter+shunt in place of the tractor ammeter. The 6V generator output is 16-19amps, but once again battery condition affects the amps at this point.
