Where can I get a Gas Screen??????
Shane Schmidt
05-27-2003 09:30:45
Hey guys,
Was wondering where I could get a new gas screen and rubber gasket for the sediment bowl on my TO-30. Mine is beginning to leak pretty badly, and I need a new one. I'm hoping someone can help.....
TIA,
Shane
kjm
05-28-2003 19:10:06
 Re: Where can I get a Gas Screen?????? in reply to Shane Schmidt, 05-27-2003 09:30:45
Shane, try the local IH Case dealer, C,M H,400 something should work.
Tex Ferguson
05-28-2003 18:34:00
Hi Shane,
I got the whole assembly from NAPA for around $20.
Gas leaking down on old Sparky the starter is a bad deal! Good luck.
Tex
Tex Ferguson
05-28-2003 18:36:00
 Re: Re: Where can I get a Gas Screen?????? in reply to Tex Ferguson, 05-28-2003 18:34:00
Forgot to say I wrapped some plumber's teflon sealer tape around the threads before screwing the assembly into the tank. No drips!
john(UK)
05-27-2003 11:36:04
cant readily locate just the filter and gasket, but the whole filter assy is available here, not expensive either, so maybe you can consider that.
but I think the same parts are used on other makes of tractor anyway so a call to your local dealer may help Link
drizler
08-05-2003 07:54:17
 Re: Re: Where can I get a Gas Screen?????? in reply to john(UK), 05-27-2003 11:36:04
If yours is bunged up at all its probably a good idea to replace the whole assembly. These can be a major pain in the neck when they start acting up. I have had 2 of them and replaceing one was the only way to cure it. When you remove it make sure to flush out the tank to get any accumulated debris out so you can start over fresh.
