Rod and Fork
Dennis West
05-23-2003 16:26:17
Anyone know where I can find the upper left hand lift rod... I thinks it's called the rod and fork... for a TO20? Are the Ford 9N/8N rods interchangeable with the Ferguson? My rod busted, and it looks to be cast, so I don't think a weld will work well. This rod had been bowed since before I owned the tractor, and after the break, I found evidence where it had been cracked half way through for many years.
Thanks...
Dennis
05-26-2003 07:23:04
 Re: Rod and Fork in reply to Dennis West, 05-23-2003 16:26:17
OK, thanks guys... I'll get it welded this weekend.
Paul in Mphs
05-25-2003 05:03:39
there is a original lift rod on E-bay
toolman
05-24-2003 19:36:50
dennis i just had mine welded thats twice now it the last 15 years they are cast and you use a nickle rod , i think it was, mine has always been bowed a bit , i just figured that was normal.
Rusty
05-25-2003 10:30:51
 Re: Re: Rod and Fork in reply to toolman, 05-24-2003 19:36:50
Mine are bent also. The one on my salvage tractor is also bent. Maybe they are designed with a little bend?
toolman
05-25-2003 15:52:56
 Re: Re: Re: Rod and Fork in reply to Rusty, 05-25-2003 10:30:51
yup i think they are, mine was when i got it ia was a school board tractor never worked too much, first time i broke it an old fellow welded it up for me said they were supposed to have a bend in them, just broke it again this past winter , backed up fast into a steel pipe full of concert, snaped it got another guy to weld it used a nickle rod , ground it down some never know it was ever welded twice , still strong too as i been workin the fields with it this spring an no problems.
Terry Mi.
05-24-2003 05:30:43
Lift arms are available at most all tractor supply stores or dealerships. Make sure you get catagory 1. If you are doing a restore project for show you may want to seek out one in a tractor bone yard, so that it will be Ferguson original. Otherwise one from the dealership or store would work.
Rusty
05-23-2003 18:00:36
Are you asking about the 3 point hitch? Some of the rods are forged and can be welded.
Dennis West
05-23-2003 19:09:40
 Re: Re: Rod and Fork in reply to Rusty, 05-23-2003 18:00:36
Yes, the three point hitch. Left hand side solid rod upper lifting arm... as opposed to it's counter-part "leveling box" arm over on the right side. It looks to be cast, and my welder confirmed this, however, I'm no expert.
Rusty
05-24-2003 06:21:19
 Re: Re: Re: Rod and Fork in reply to Dennis West, 05-23-2003 19:09:40
You should be able to get them at any tractor salvage yard.
