Rear axle seal replacement
Rick NC
05-23-2003 06:05:38
Anyone ever changed rear axle seals on a 1950 TO-20????? ? got a question about the axle collar.
rp
05-23-2003 12:23:10
 Re: rear axle seal replacement in reply to Rick NC, 05-23-2003 06:05:38
My 1951 TO-20 leaked on both sides. I installed Shure-
seals without any trouble. Much simpler than pressing the bearings on and off to get to the original.
Rusty
05-23-2003 17:52:19
 Re: Re: rear axle seal replacement in reply to rp, 05-23-2003 12:23:10
The sure seals are cheap and they seem to work good. You just about have to split the collar to get it off and replace the original seals.
Rick NC
05-23-2003 18:26:36
 Re: Re: Re: rear axle seal replacement in reply to Rusty, 05-23-2003 17:52:19
Hey, thanks for the replys, not familiar with sure seals. Any info would be appreciated--Rick
NCtim
05-24-2003 04:32:04
 Re: Re: Re: Re: rear axle seal replacement in reply to Rick NC, 05-23-2003 18:26:36
Your Massey-Ferguson dealer has them. Mine were installed at $15.00 each, included parts and labor.
NCtim
Jim
05-29-2003 19:12:31
 Re: Re: Re: Re: Re: rear axle seal replacement in reply to NCtim, 05-24-2003 04:32:04
I have just had new rear axle seals put on my TO20 but have a question about what to use for the gasket between the end of the axle housing and the brake backing plate. The dealer I bought the shims from said to use them for the gasket but they are so thin I am not sure this is correct. I am also hoping to find metal shims which is what was on there when I took the axles out. I have only been able to find paper style.
Any help would be appreciated
Thanks Jim H Cooperstown, New York
