Temperture gauge for tea 20
Scott
05-20-2003 11:28:22
I HAVE A Ferguson TEA 20 and would like to install a temp. gauge. My problem is that I don't know where on the engine to install the sending unit. The sending unit is a 1/4 pipe tread. Does anyone have any ideas?
Thanks Scott
James, UK
05-22-2003 04:28:04
 Re: temperture gauge for tea 20 in reply to Scott, 05-20-2003 11:28:22
If you don't want to drill and tap your housing, see if a thermostat housing off a TED will fit yours - it might save you a lot of grief . . . .
Peter.U.K.
05-21-2003 02:35:27
Only the TED was factory fitted with a temperature gauge. To fit one to a TEA you will have to drill and tap the thermostat housing.
john(UK)
05-20-2003 12:49:46
It screws into the thermostat housing on the left side near to the by-pass hose, as it is a petrol it may have a blanking plug in place OR it may not be drilled at all. Usually though there is a blanking plug.
