TO 30 AND Tiller
Glen
05-20-2003 09:21:33
Have a chance to get a TO 30, was wondering if anyone has used a 5 food tiller with this tractor,off the pto, and how did it do, good-bad.
Thanks
James, UK
05-20-2003 21:48:47
 Re: TO 30 AND Tiller in reply to Glen, 05-20-2003 09:21:33
I agree with Phil - use a 35, or try to find a TO with a Sherman or similar reduction box (rare).
If you plough (plow) first, you get pretty good results with a set of disks. Or if the ground is not too hard use a spring tine type cultivator. Neither of these will give you the 'panning' effect and drainage problems you can get if you keep cultivating over and over with a tiller.
The above implements are also cheaper to buy second hand than a tiller and need less maintenance, cheaper spares etc. . . . . . . hint hint.
Phil (VA)
05-20-2003 10:49:36
Tillers don't work well on these tractors. First gear is too fast. If you get a 35 with a high and low range tranny, it might work ok.
