TO-20 Engine Outlet Elbow
Tom
05-19-2003 20:04:20
Attempting to find out the correct name for the engine outlet elbow, water jacket, etc. This is the casting from the top of the valve block to the radiator return. I have tried various names and the TO part number on the casting but have not located this item.
James, UK
05-20-2003 21:41:45
 Re: TO-20 Engine Outlet Elbow in reply to Tom, 05-19-2003 20:04:20
Tom,
I checked on my TED last night, and the casting is integral with the cylinder head - at least it is on a Standard engine - if yours is a Continental perhaps it is different - Continentals over here are not that usual - we consider them almost rarities!
Good luck with Ray's list of salvage yards.
Ray.IN
05-20-2003 19:17:54
The part is called a "gooseneck", the proper name escapes me. The thermostat does not fit there, it goes inside the upper radiator hose. Here's a list of North American salvage yards.
James, UK
05-20-2003 00:23:37
Try 'Thermostat housing' - it's what we would call it over here.
Its aluminium, yes? And bolts onto a cast iron 'snout' coming off the front top of the cylinder head?
I have seen 'new' not OEM ones available, but cannot remember where. Will post link if I can remember . . . . . . .
Tom
05-20-2003 06:06:24
 Re: Re: TO-20 Engine Outlet Elbow in reply to James, UK, 05-20-2003 00:23:37
It's the "cast iron snout" of the valve block that I'm looking for.
James, UK
05-20-2003 06:20:14
 Re: Re: Re: TO-20 Engine Outlet Elbow in reply to Tom, 05-20-2003 06:06:24
Aaaahhh, I see now.
But I cannot help, as I don't think it has a name - you could try 'lower thermostat housing'?
I thought it was an integral casting with the cylinder head - at least, that's how I remember it, but will check on mine when I get home.
From the sound of it, you may have to resort to a long hunt around scrap yards and breakers to find one.
You could try Appleby's of Silsden (see link below) who may be able to help - at a cost . . . .
If nothing else you could ask them for more details or advice at any rate. I am sure they would help.
If you still have some of the parts (if it's just broken, rather than missing) you could try re-creating the shape from JB weld or similar - as the pressure the cooling system runs at is quite low.
Good luck, and hope this helps.
