TO 20 hood
Tom/Idaho
05-17-2003 05:59:13
I have a TO 20 with a Superior loader and due to it's configuration I can't put the grill or hood on (front mounted hyd pump and pump guard). Will a different hood with the gas tank opening down the middle fit, say from a 35? I could probably modify this hood and grill to work, but I would rather have one that looks better. Thanks, Tom/Idaho
Phil (VA)
05-19-2003 08:38:33
 Re: TO 20 hood in reply to Tom/Idaho, 05-17-2003 05:59:13
I have an old TO-30 hood (same as TO-20) which I will sell, if you are interested. You could cut hold for radiator and for gas filler and not have to mess up your hood. If you ever take loader off, you will still have yours. I am in VA. It isn't heavy, but difficult to ship. Let me know.
John
08-04-2003 20:01:07
 Re: Re: TO 20 hood in reply to Phil (VA), 05-19-2003 08:38:33
Hi, I have a TO-20 and I do need a hood and grill. The guy I got this from had a loader on this tractor and gave the hood to the scrap yard. How much for the hood? Pappy,
Paul in Mphs
05-19-2003 16:11:40
Shame on you talking about cutting holes in a to-20 or 30 hood. Thats a hanging offense in some parts.
Paul in Mphs
05-21-2003 05:35:24
 Re: Re: Re: TO 20 hood in reply to Paul in Mphs, 05-19-2003 16:11:40
What he needs is a side mount pump from Zane. You would think some aftermarket company would make new grills for to & te,s
Phil (VA)
05-21-2003 11:35:06
 Re: Re: Re: Re: TO 20 hood in reply to Paul in Mphs, 05-21-2003 05:35:24
Yeah. The bottom of my grill is the only real bad part, and he would have to cut that out anyway to make the stinger from the pump fit.
Phil (VA)
05-20-2003 07:08:49
yeah, i know. the one i have available needs a good bit of work, although it is restorable. the only real bad spot is under the grill. i was thinking if he was going to cut one up, he might as well cut up one that needed work anyway.... really you have to also cut the top and install hinges too, otherwise you still can't get to the battery. if his is kept in a shed, he might just want to leave the hood off.
Paul in Mphs
05-17-2003 08:04:34
I was able to compare a 35 hood to my to-20. Length was close, height on the 35 hood was 3 inches to tall. I decided not to modify the 35 hood.
