TO-30 Thrust end play
Scott
05-15-2003 06:10:52
I am rebuilding a TO 30 (Z129 Continental) which had previously been assembled wrong and the crank was floating back and forth. By doing this, it ruined some of the shims used to set end play, Does anyone have some of these shims, located behind the crank gear, they would like to sell? or know where I can get them, My local MF dealer has not been able to find them. Thanks in advance for all your help. I apologize of this sounds like an advertisement, these !@#$%!! shims are all that's keeping me from getting her back together
ErnieD
05-15-2003 15:19:14
 Re: TO-30 Thrust end play in reply to Scott, 05-15-2003 06:10:52
I believe the washer is a fibre composite. Ours broke and I found it in the oil pan. Like the others said, you can make your own.
Rusty
05-15-2003 14:19:35
I found the shims at an auto parts store that also sells tractor parts. They gave me some shims that were really for something else but worked for the tractor. Some of the shims are still hanging in the shed. A transmission shop may also be able to help. You could also get shim stock and make shims but that is a pain in the kaboose.
Scott
05-15-2003 07:03:25
Call these guys they will have what you need.
LAKESIDE IMPLEMENTS.
608-296-2045
gerry
05-16-2003 07:25:47
 Re: Re: TO-30 Thrust end play in reply to Scott, 05-15-2003 07:03:25
where is lakeside implements located?
Duner Wi
05-15-2003 11:50:09
Sealed P0ower lists the following. Thrust washer set to be used with single flange #1 bearing. Part# of Thrust washer set is MS 1403W for use with main bearing set #MS 259B. I don't know what is encluded in the set.
