TEA 20 PTO Lever Stuck!
Ross M, UK
05-14-2003 07:11:57
Since changing the PTO seal my PTO Lever has become stuck! Anyone Ideas why? Should have been in a certain position when replacing the shaft???
Jeremy Deakin
06-05-2003 11:05:38
 Re: TEA 20 PTO Lever Stuck! in reply to Ross M, UK, 05-14-2003 07:11:57
I Had a simliar problem. When you put the pto lever back you need to make sure that the lever end is in the guide thing that is in front of the cog on the shaft.
I suggest putting the lever in the neatral position puting the cog manually in the neatral position wher it just spins and then bolting up.
David (Scotland)
05-15-2003 08:37:46
Don't really know what might be stuck but since no one else is replying I'll make a few suggestions. Take side plate with PTO lever on it off and have a look inside. (you may need to tilt tractor to one side to stop oil coming out. Level is just at bottom of hole usually.) You may need to drain oil to see what's happening, or not happening but I would look first with oil in. Don't see that there would be any obvious reason for lever to be stuck unless you have had side cover off already and put it back without lever properly engaged on the shifter. If you can't see anything I would draw the shaft again and put it back with PTO lever in neutral and see if that frees it.
Ross M, UK
05-16-2003 06:25:02
 Re: Re: TEA 20 PTO Lever Stuck! in reply to David (Scotland), 05-15-2003 08:37:46
I'll try the side plate tomorrow.
If its not that then i'll have to withdraw the shaft again.
