What is it
Chris
05-12-2003 05:35:52
I have a H F tractor with a serial # TO-22???. It is a 4 speed with high and low range, starter is on the gear shifter, Back axile has a # of TO-4012 on the left and TO-4014 on the right. The tractor seems to be about the same size as a 9n. I thought it was a TO-40 but it does not look like any TO-40 pictures that I've seen. Looks pretty close to TO-20??? Any help would be great.
Chris
Phil (VA)
05-12-2003 06:21:20
 Re: What is it in reply to Chris, 05-12-2003 05:35:52
Sounds like you have a 1950 TO-20. The engine number should start Z120.... And the oil filter should be inside the pan. If so, that's definitely what you have. Of course, you have an add-on high-low tranny. Having an extra set of gear ranges may be what made it seem like a 35 or a 40 if you didn't have either of those to compare to. You are correct that your tractor is very much like a 9N, but one major difference is yours has the overhead valve engine.
