Perkins P3 Oil filter/Other parts
Simon Dyer
05-12-2003 04:57:10
Please can anybody let me know the parts number for an Oil filter for this '52/53 engine that I have in my narrowboat?
I have managed to find a replacement impellor from Jabsco for the 4330-01 water pump if anybody needs the information re this part!
It appears that Perkins UK are most unhelpful as they write the P3 off stating that the engine is OLD! Cleghorn-Waring did not want to originally sell me the 'substitute' impellor, advising me to replace the original water pump with a new pump that would require new welded brackets and re-siting the thing! I insisted on buying the impellor and am trial running...no probs so far....Anybody who would like to discuss this P3 engine is welcome to phone me on +447740240004(in UK, replace +44 with an 0!)
Many thanks,
Si
Dan
05-15-2003 01:47:57
 Re: Perkins P3 Oil filter/Other parts in reply to Simon Dyer, 05-12-2003 04:57:10
The P3 is actually a p3,144 virtually identical to the Fordson Dexta apart from having a timing chain and different oilpump. The Super Dexta and MF35/135 were fitted with the 3,152 which is basically just a bored out version and still in production for non EU countries (Emmissions reg problems)When i rebuilt my Dexta, a perkins specialist was most helpful and even had pushrods on the shelf (although Cat had only just taken over Perkins) of course filters are usually generic, so you may be able to get them off a filter specialist if all else fails.
James, UK
05-12-2003 07:35:33
Si,
you could try phoning the Old 20 Parts Co. on 01332 792698, or Southern Counties Tractor Spares on 01243 512109, or go to the link below, or phone Holland Brand on 08707 459 075, or go to www.fergiebitz.com - they should all be able to help you.
I have no connection with any of them.
Simon A. Dyer
05-13-2003 04:24:11
 Re: Re: Perkins P3 Oil filter/Other parts in reply to James, UK, 05-12-2003 07:35:33
Many, many thanks!
best wishes,
Simon
