Hydr. pump parts
paul ferguson
05-11-2003 22:33:34
Hello, just dropped my hydr. pump on my 51 TO-20 so I could clean and inspect..Wow what a lot of crud buildup..Are there any seals or anything that should be replaced? What about the two side cover gaskets and the pump pan gasket<< where does one get these? Thanks for anyones help..Paul
john(UK)
05-12-2003 11:30:40
 Re: hydr. pump parts in reply to paul ferguson, 05-11-2003 22:33:34
The build up of crud as you call it is due to not changing the oil often enough. Parts are available, depends on where you are located USA or UK, if you let us know we can point you in the right directon.
paul ferguson
05-12-2003 21:39:08
 Re: Re: hydr. pump parts in reply to john(UK), 05-12-2003 11:30:40
Hello, Im in the US... I bought this tractor about 1 1/2 yr ago, and never changed it till now....Thanks again.Paul
john(UK)
05-13-2003 12:30:38
 Re: Re: Re: hydr. pump parts in reply to paul ferguson, 05-12-2003 21:39:08
Link
Link
These are just two companies that supply parts, but there are many more, suggest you go to "www.google.com" and type in "Ferguson Parts" see what comes up for near you.
