Nut on front pulley
Damon
05-11-2003 15:11:11
Dear all,
I am asking this question on this board as the engine that drives my Massey Harris 701 baler is the Standard 4 cylinder as found in the TEA20.
I would like to know does the nut which is located on the front pulley hold the pulley on? The nut sheared off on the weekend when I was trying to use the crank to help free the engine. I have since freed the engine with a block of wood, oil and a hammer, with no apparent damage.
If the nut is essential for other purposes than crank starting (plan to get a starter motor)how is it replaced?
Thanks in advance for your help,
Damon
Jim W
05-11-2003 19:23:44
 Re: Nut on front pulley in reply to Damon, 05-11-2003 15:11:11
On my TEA20s it's a bolt rather than a nut, and it does hold the crank pulley on.
If you are going to replace it I suppose a regular bolt would do but it has fairly fine threads. I don't know if it's a "standard" pitch.
Jim W
