Regulator wiring for TEA 20
Glynn Gangell
05-07-2003 07:57:43
I am restoring a TEA 20. The regulator does not have any wires attached to it. Would anyone have the wiring sequence? There are 5 x terminals. Thanks.
Jim W
05-07-2003 09:37:36
 Re: Regulator wiring for TEA 20 in reply to Glynn Gangell, 05-07-2003 07:57:43
E is for Earth (ground)
D is for Dynamo (generator output)
F is for Field (of the generator)
B is for Battery - or it might be A for Accumulator
I can't remember what the fifth terminal might be; I think there could be two the same (connected to each other).
Jim W.
Glynn
05-07-2003 19:05:53
 Re: Re: Regulator wiring for TEA 20 in reply to Jim W, 05-07-2003 09:37:36
Thanks Jim,
I've just about got it. There's two terminals for A - that is A1 and A. Any thoughts?
Jim W
05-07-2003 20:02:12
 Re: Re: Re: Regulator wiring for TEA 20 in reply to Glynn, 05-07-2003 19:05:53
Now I am looking at some wiring diagrammes but they all have only one A terminal. I suspect that A1 and A are the same, and perhaps you have a different regulator, like a later replacement or so.
Do you have five wires to connect? What colours are they?
Jim W
Glynn
05-07-2003 20:33:45
 Re: Re: Re: Re: Regulator wiring for TEA 20 in reply to Jim W, 05-07-2003 20:02:12
Jim, All wires, except the two from the generator, are missing. I'll have to re-wire it.
Al (Canada) mailed a wiring diagram - for a four post regulator. I'll do as the diagram shows and I may just leave out one of the A terminals and see what happens. A flip of a coin may decide as to which one.
john(UK)
05-07-2003 10:46:57
A is for ammeter. what are the letters along the edge of the box? if you let us know maybe we can work out what it is
Glynn (Australia)
05-07-2003 18:50:23
 Re: Re: Re: Regulator wiring for TEA 20 in reply to john(UK), 05-07-2003 10:46:57
Thanks John,
The five terminals are: A1,A,F,D,E.
Glynn
Australia
Glynn (Australia)
05-07-2003 18:49:25
Thanks John,
Glynn
Australia
James, UK
05-08-2003 00:13:28
 Re: Re: Re: Re: Regulator wiring for TEA 20 in reply to Glynn (Australia), 05-07-2003 18:49:25
Jim W is pretty much on the button, F = Field, E = Earth, A = Accumulator (Battery), D = Dynamo output.
I would also suspect that A1 is for the ammeter.
Glynn
05-08-2003 05:56:49
 Re: Re: Re: Re: Re: Regulator wiring for TEA 20 in reply to James, UK, 05-08-2003 00:13:28
Thanks James, I think you may be right
