How to polarize the generator??
George
05-07-2003 07:52:45
This may have been posted before, but how do you repolarize the generator?
6 V Battery was installed with neg ground, I want to change back to pos ground. But I think I need to repolarize the generator and I don't know how.
thanks
David
05-07-2003 14:27:20
 Re: How to polarize the generator?? in reply to George, 05-07-2003 07:52:45
I did mine a while back and from memory all that was involved (with battery connected as you want it to be) was to briefly touch the live wire (the thick one) to the smaller terminal on the dynamo. Maybe someone else can confirm this. I'm fairly sure that is correct.
James, UK
05-08-2003 00:09:29
 Re: Re: How to polarize the generator?? in reply to David, 05-07-2003 14:27:20
Yup, that's the way to do it. I was told that a gentle 'stroking' of the live wire across the field terminal (since it is the magnetic field you need to reverse) is what is needed, rather than a constant current/voltage.
It has always worked for me.
