TEA oil out air intake
Jim W
05-05-2003 05:03:12
I have the later TEA with the grille on th edashboard, and the rubber tube between the dash and the air filter canister. This weekend under light intermittent use, oil started coming out and oozing down the dashboard. It was running as normally as it ever does.
I am puzzled. Any ideas?
Jim W
john(UK)
05-05-2003 12:58:15
 Re: TEA oil out air intake in reply to Jim W, 05-05-2003 05:03:12
Sounds like back pressure in the engine is causing it. But it could just be the air cleaner partly blocked, try removing the whole thing and washing it thoroughly. if there is a lot of pressure coming out of the breather hose from the engine to the air cleaner, it could be the piston rings or bore is worn allowing "blow by" to occur
Jim W
05-05-2003 14:58:27
 Re: Re: TEA oil out air intake in reply to john(UK), 05-05-2003 12:58:15
Good points; I will check these things and hope it is the air cleaner. Maintenance there is certainly overdue.
Thanks,
Jim W.
john(UK)
05-05-2003 12:51:47
