TO-30
Doug U
04-29-2003 18:33:09
We are trying to repair a front pto on a (I belive a TO-30) ser # TO330330 Ferguson tractor. It has a front end loader on it which has a hydraulic pump mounted on the stationary plow frame. From there is a coupling attached to a 5/8" shaft which is left hand threaded into a 4 hole flange approx 2 1/2 inches in dia. The flange and shaft were hanging when I found this tractor. It appears that there were 4 pins in the flange that extended into rubber busshings which were situated in 4 indentations in the crankcase pulley. The pins are gone (one broken off in a whole of the flange)and there was one rubber washer of sorts left in the pulley. Am I figuring this correctly? Are there flanges, pins and rubber washers available? Thanks!!!
Phil (VA)
04-30-2003 06:58:41
 Re: TO-30 in reply to Doug U, 04-29-2003 18:33:09
This is the same arrangement as the Wagner and Dearborn loaders have for the old Fords. I believe the New Holland (Ford) dealers have some of those parts. You might try them. Also try Dennis Carpenter, phone 800 476 9653. Hope that helps.
Pilgrim
05-01-2003 05:57:15
 Re: Re: TO-30 in reply to Phil (VA), 04-30-2003 06:58:41
Any dealer that uses TISCO as its parts supplier has them.
