TEA loose timing chain
Jim W
04-29-2003 17:48:06
This is bad; I should remember because I just put one of these engines together not that long ago:
Putting the timing chain on, there seems to be a lot of slop. These engines have no tensioner - do I have a too-well-worn chain or is it normal that there is lots of slack?
Note this is a Standard engine, not Continental.
Thanks,
Jim W
kevin
04-30-2003 17:17:02
 Re: TEA loose timing chain in reply to Jim W, 04-29-2003 17:48:06
Check it with a protractor or degree wheel. What seems like a lot of slop is usually quite minimal. If you have less than 5 crankshaft degrees of play, you,re OK.
John
04-30-2003 12:00:49
There should be no slack in the timing chain at all..while you are looking at it check the governor weights and plate, if the chain is worn no doubt the governor will be too, if a weight comes off it can go through the timing cover. Parts are available.
Peter, U.K.
04-30-2003 02:06:28
Jim, Sounds like you have a worn chain, there shouldnt be much slack at all when the chain is fitted.
Jim W
05-01-2003 18:50:49
 Re: Re: TEA loose timing chain in reply to Peter, U.K., 04-30-2003 02:06:28
Well then I guess I need a chain alright. There is certainly more than hardly any play at all. In fact the reason it needs to be replaced is that the original one broke and went through the cover. A weight also came off the governor so who knows which caused what.
Anyway this is a spare chain from another tractor but it surprises me that it's even possible to wear this much. Also, I was told that a TR3 timing chain would fit, but a TR3 has a chain tensioner. So - do I get these from the MF dealer? (Note to TO20 users: this is not a Continental engine, and the usual recommended suppliers in the US barely carry anything for a TEA engine.)
Thanks,
Jim
