TO30 Lift Height
phil bailey
12-28-1999 13:01:52
My TO30 lift works ok, holds good, except it doesn't lift high enough to work post hole digger or boom pole, etc. I have loosened lift plate and slid back to adjust and didn't help much. Only lifts about 2/3 normal height, fine for blade, but not for post hole digger. Suggestions?
(Appomattox, VA)
hunter
12-30-1999 16:50:28
 Re: TO30 Lift Height in reply to phil bailey, 12-28-1999 13:01:52
Phil, used my to-30 with a posthole digger and it works fine. be careful with that thing since theres no live lift.
rod
12-29-1999 14:15:01
Do you have correct links? try removing links from rockshaft arms them put lift up to see if it might be binding if the lift links are on wrong {there is a notch} the arms will not lift enough. this is most simple to check ok
regards
rod
