TO-30 runs like a dog
VA
04-17-2003 16:55:16
Hi. MY TO-30 will only keep running on half choke, anything less and its coughs, sputters and pops till it dies. I try to adjust the carb and it only gets worse either way I go. I drained the tank and carb but it did not help. The tricky part is it ran great for several hours one day this winter, it ran bad before and ever since. My next move would be to take apart the carb. What else should I look for. Thanks in advance for any response. VA.
Jim
04-18-2003 11:07:06
 Re: TO-30 runs like a dog in reply to VA, 04-17-2003 16:55:16
VA,
Recently had problems with a '55 TO-35 Deluxe; the symptoms were similar to SOME of those you described. Thought for sure I had fuel/Carb. problms: backire (maybe wrong fuel/air mixture), pops, rough idle, half choke till engine warmed etc. There was some sediment in the fuel bowl but real improvement came after replacing plugs, wires, Dist. Cap, rotor bug, condenser, & points. I don't use the choke anymore. Maybe something else for you to consider.
Jim
Tex Ferguson
04-17-2003 18:54:14
Hi VA!
Sounds like the problems I had with my TE-20. I knew my tank was rusty, but when I opened up the carb there was 1/2 inch of fine-grain rust clogging the float bowl! Eventually this layer would have prevented the float from dropping to open the valve. I installed a rebuild kit and an inline fuel filter I got from NAPA and I haven't had any carb problems since. Good luck!
Tex
