TO--30 Exhaust
Jim Polanosky
04-11-2003 07:21:17
I recently purchased a '52 TO-30 w/ the Z129 engine. The exhaust pipe & muffler have been mounted vertically off the side of the engine; I've seen other pix that show the exhaust routed under the tractor like an 8N. Questions:
* How was the exhaust routed when it came from the factory? * Is there a benefit of routing vertically vs horizontally?
Thanks for your time!
phil fenner
04-11-2003 22:22:40
 Re: TO--30 Exhaust in reply to Jim Polanosky, 04-11-2003 07:21:17
Two things about the vertical exhaust are noise and fumes for the operator to be exposed to.
Phil(WA)
Joe Ferguson
04-11-2003 15:49:15
Hi Jim
I have two TEA-20 with horizontal
and one MF-135 with vertical.
I think it depends of the use of the tractor
If used with 3pt cement mixer or wood splitter
it is preferable to have vertical exhaust system
to avoid to inhale exhaust gasses. It is also
appreciated when you are attaching an implement while engine is running.
However if you go in the woods or working where there are many trees with branches or your garage door is not too high.... horizontal system is preferable. If vertical hits something there is a risk to break the exhaust manifold.
The TO's came from the factory with horizontal
type. There were vertical kits from third parties for special purposes. In my gas MF-135 manual there is a vertical muffler kit sold by MF.
Good luck with your new one !
Joe Ferguson
Jim Polanosky
04-14-2003 13:21:53
 Re: Re: TO--30 Exhaust in reply to Joe Ferguson, 04-11-2003 15:49:15
Thanks to all who replied! I'll probably keep the exhaust Vertical for now - a few other things to worry about first!!
Jim Polanosky
04-14-2003 13:21:35
Randy
04-11-2003 09:11:54
Jim: I don't know for sure, but I think they came from the factory with the horizontal muffler. The advantage with the vertical is that long grass can be set on fire from contact with a hot exhaust. The vertical eliminates that risk.
Jim Polanosky
04-11-2003 10:41:22
 Re: Re: TO--30 Exhaust in reply to Randy, 04-11-2003 09:11:54
Randy;
Thanks for the quick follow-up! Makes sense to have the exhaust vertical - don't know whether I'll keep it this way or put it back horizontal. Don't have to worry about fire - have 3/4-acre of clay from new construction, now soaking wet from 1 wks worth of heavy rain! Of course, don't think I'll be doing much box-scraping until it dries out! Thanks, Jim
Jim Polanosky
04-11-2003 10:41:05
Randy;
Randy
04-11-2003 14:56:26
 Re: Re: Re: TO--30 Exhaust in reply to Jim Polanosky, 04-11-2003 10:41:05
Jim: One thing I forgot, the horizontal exhaust has been known to clog with snow, or dirt when using the rear blade if it piles up thick in front of the blade.
