PTO cap
Randy
04-11-2003 04:49:00
Folks: I recently got a cap to cover the PTO shaft on my MF35. Don't want the shaft to get any damage, but the outside thread on the housing, the first one the cap should engage is a little damaged so the cap won't go on. Any one got any ideas on how to fix that thread? Thank-you.
rp
04-14-2003 20:17:26
 Re: PTO cap in reply to Randy, 04-11-2003 04:49:00
I also responded to this over in another forum...
Just dremel the first thread flat (out of the way). Your cap will then engage at the first "good" thread.
rp
rp
04-14-2003 20:14:55
rp
James, UK
04-14-2003 00:27:02
It's an external thread? If so, you can use a proper thread file (if you can find one) or the thinnest needle file you can lay hands on to clean up the damage.
It won't look 100%, but with care, if you remove the thread form that has been bent over into the thread valley, you will get the thread working again.
Be patient doing this . . .
HTH
