Throttle creepinf
Bubba
04-06-2003 08:38:18
I have noticed my throttle starting to creep i have put hacksaw blades behind the disc but no help lookin at it today i found no tension on the plunger spring could this be the problem and where can you find one.thanks bubba
todd(MI)
04-06-2003 14:34:22
 Re: throttle creepinf in reply to Bubba, 04-06-2003 08:38:18
I made a disk out of a rubber mat I had laying around about 1/8" thick. I cut a circle with a hole saw (don't rember how big it was)then I cut the center hole with a slit in it so I could put it on without taking the throttle apart. I also tightened the spring behind the dash. Pain in the butt if I remember rightly. You have to losen a nut, compress a spring, and retighten while holding the spring. Process would have worked better if I had 3 hands. the throttle holds now, but about every week or so depending on use I have to readjust the rubber disk. it keeps wanting to work itself out from behind the throttle. I made another rubber disk and diddn't put a slit in it and one of these days I'll get around to putting that one on. up to you fast and easy or the right way.
Todd
