Thermostat
bubba
04-04-2003 16:37:23
folks i have taken my gas tank out removed top hose section completely and still have not found thermostat or where it might go post on here say in hose but all i see is something that looks like a bolt screwed in a hole on side of bracket i can see staight through hose nothing there....thanks bubba
Bubba
04-06-2003 08:34:17
 Re: thermostat in reply to bubba, 04-04-2003 16:37:23
thanks for all the help didnt have one in it, it was just hard to believe where it would have been if it had been there thanks again ..Bubba
Ray,IN
04-05-2003 20:58:52
The stat fits inside the top hose, a slip fit. It is readily apparent if was there. They may be bought at a Carquest store, a MF dealer, a NAPA store.
kevin
04-05-2003 08:38:18
Sounds like someone before you has removed it . The bolt on the side is actually likely a plug. You could put the sender for a temp guage in that hole.
Jim W.
04-04-2003 19:53:02
which engine?
Bubba
04-05-2003 04:00:18
 Re: Re: thermostat in reply to Jim W., 04-04-2003 19:53:02
the engine is a continental z120, i have the hose completeley out of the tractor along with the goose neck nothing resembling a thermostat in there what is the bolt hole on the side of the gooseneck for thanks..bubba
marlowe
04-04-2003 16:44:45
it's in the front of engine where the hose goes on the tractor in the thing called the goose neck it's held by two bolts and a gasket. this is the top hose!
