To-35 experts
Ted
04-04-2003 09:47:12
Can't get the stud that holds the bottom link of the three point to stop spinning so I can remove nut. Its located right under the rear axle. Is there a nut on inside of that rear end housing that needs to be held?? Got manuals but nothing is shown on that. Also got my manifold off, is there a way to take the two piece manifold apart? Its a gas 134 engine. It appears that the carb flange was pressed on after the intake and exhaust were interlinked. Any thoughts, thanks Ted
Big Dean
04-04-2003 14:00:50
 Re: To-35 experts in reply to Ted, 04-04-2003 09:47:12
The pin is taper where it fits in the axle housing it has a nut on the inside hat pulls it up into the tapered area tight. If you don't pull the axle housing & tighten that nut it will wallow out the hole in the axle housing till it will not hold a pull pin. You may have to replace the pin to get it tight.
Phil (VA)
04-04-2003 11:56:00
Head of stud is on inside of trumpet assembly as I recall. Pain in patootie. Maybe you can get big vice grip on the stud. Or weld something to it that you can cut off later, etc. Like weld a rod to it and then put a pipe over the rod to jam into ground to hold it until nut loosens.... Of course, then cut the rod close so nut will come off over it. Just a wild thought if you don't feel like pulling the housing apart.
