MF 35 vs. Ferguson TO-35
Mark Young
03-14-2003 17:25:20
I found a service manual for a Ferguson TO-35, and was wandering if it would be compatible with my 1958 MF 35. Is there any mechanical difference between the two tractors?
Dave R.
03-15-2003 20:55:36
 Re: MF 35 vs. Ferguson TO-35 in reply to Mark Young, 03-14-2003 17:25:20
Is it not possible that some late TO-35's had MF decals? If not what decals did they have?
Dick/Sonoma, Ca
03-15-2003 12:22:28
Mark
It might be a big differance if your Massey Ferguson 35 has a Standard-Vanguard gasoline engine like my FE35. Do you know what motor you have? I gather that the rest of the drive train may be the same. Do you know if the TO35 manual covers your engine?
If you have the Standard engine I would like to talk to you and compare notes. I've been trying to find out the answere to some similar questions.
/Dick Nyquist
John
03-15-2003 05:31:50
There is very little difference between these two models, all the mechanical bits are the same just the tinwork is different apart from a few odds and ends the answer will be No difference.
Paul in NM
03-15-2003 04:14:23
Mark, if your tractor is a '58, it is a TO-35. Someone may have put MF decals on it. Even if it were to be a MF, they are virtually identical mechanically. The MF had the option of a Perkins diesel while the TO had the Standard Diesel option. If you will post your tractor SN, the year can be ascertained quite easily.
H.T.Hertz
03-22-2003 13:48:49
 Re: Re: MF 35 vs. Ferguson TO-35 in reply to Paul in NM, 03-15-2003 04:14:23
Sorry to disappoint you here, but the european MF-35 came with the Standard 87mm bore Gas or Standard 23c diesel until 1959, when the perkins 3-152 replaced the Standard in the Diesel version. (later 35x with A3-152)
The M-F might be a late '58, as the FE-35 name change took place this year.
Henning Hertz
Taageskov
Denmark
