To30
rlg
03-13-2003 15:07:33
im looking for parts for to30 thanks
Dale in WV
03-13-2003 18:11:55
 Re: to30 in reply to rlg, 03-13-2003 15:07:33
got an extra brake pedal -- also a seat spring. You need more than that??
Dennis
03-13-2003 16:56:08
What parts are you looking for?
rlg
03-14-2003 04:25:07
 Re: Re: to30 in reply to Dennis, 03-13-2003 16:56:08
what i need the most is an exhaust manifold. maybe an axle. one of the wheels on my dads tractor kinda wobbles real noticeable in 4th gear havent tore it apart yet . it was like that when he bought it. and i could use a hood but i know there few and far between thanks.
Paul (WI)
03-14-2003 16:59:36
 Re: Re: Re: to30 in reply to rlg, 03-14-2003 04:25:07
If the reason that you need a manifold is because your exhaust manifold is ate away in places, you can possibly repair it. The manifold on my TO-20 looked pretty bad. I spent about 1/2 hour on it with a large file and it has been working out well for about five years now. What I did was lay a good file flat on the manifold surface and mill it down by hand until there was plenty of good surface for the gasket. You can lead the file to take a little more metal off in the bad spots. It does require expending some elbow grease. :o)
Phil (VA)
03-14-2003 07:38:31
Post your email and others can email you directly about what they may have. I have a hood and grille assembly for the 'TO' tractors. The hood is very good, but the grille needs some work. I'm in Virginia. You can email me back and we can talk about it.
Phil (VA)
03-14-2003 07:41:23
 Re: Re: Re: Re: to30 in reply to Phil (VA), 03-14-2003 07:38:31
Sorry, I do have your email. My mistake. I will email you directly.
