Oil Pressure too high?
Donnie
03-13-2003 11:58:46
I have a TO35 (engine Z134 gas) that had the engine rebuilt recently. After two hours running, It blows oil out the rear seal, distributor mount and excessively out the oil breather hose. When I loosen the oil cap, all the leaks stop. The oil breather hose is not clogged. What could it be? Will it hurt to run the tractor with the oil cap loose. It is not burning any oil either.
Help Please!!
Al in BC
03-13-2003 14:34:50
 Re: Oil Pressure too high? in reply to Donnie, 03-13-2003 11:58:46
Donnie.
Seems like you are producing sump pressure.
Possiblity that on break in you may have broken some rings (compression). When the engine was rebuilt were the right rings for the bores installed. I am not firmiliar with that Continental engine, whether it has liners or not. Maybe there were undersized rings installed when the bores were worked on. The bad news is that if this is the case you will have to pull the engine down and start over again. My 2 cts worth
Happy fixin.
Al.
David
03-13-2003 15:13:11
 Re: Re: Oil Pressure too high? in reply to Al in BC, 03-13-2003 14:34:50
If it was new rings into old bores that have a wear ridge at the top and this wasn't removed its possible that this could break new rings. Some replacement rings have a chamfer on the top edge to stop them hitting the ridge. Does sound like a blocked breather though.
