Wiring diagram
jeff
03-07-2003 17:09:52
can anyone tell me where on the computer i can print out a wiring diagram for my TO30,it now is 12 volt system with a 6 volt starter,has alternator instead of generator, negative ground.battery keeps loosing charge, has new battery and alternator,i'm thinking there must be a bad wire somewhere,also has a new starter switch.i'm looking for a diagram i could print out. thanks for all the help everyone has been giving me.
John
03-08-2003 05:58:48
 Re: wiring diagram in reply to jeff, 03-07-2003 17:09:52
Try this site for a wiring diagram for your tractor.
http://www.geocities.com/MotorCity/Downs/9828/
John, In
03-08-2003 04:26:14
Go to Parts & Pieces to the left, page 3 I think. I posted my 12 volt wiring diagram there. It is for a 20, but should work for a 30 as well.
Bill H.
03-07-2003 19:38:28
Jeff, I converted my TO 20 to 12 volt negative ground with the same set up that you describe. I initially had problems because I had not tighten the alternator,waterpump belt enough. I changed pulleys with the conversion and I had to make a little adjustment on the alternator belt tension. Check the alternator with a volt meter. It should be reading 14+ volts when the tractor is idled up. Bill H
