Zang Thang
Garry
03-07-2003 07:04:29
Who sells the zang thang and does it work on the TO-30?
Paul F B
03-09-2003 21:16:00
 Re: Zang Thang in reply to Garry, 03-07-2003 07:04:29
Gary; Here's the URL
Tom Detweiler
03-19-2003 09:08:11
 Re: Re: Zang Thang in reply to Paul F B, 03-09-2003 21:16:00
Supposed to keep your implements in position as you use them, via a crude feedback linkage, but it doesn't, at least on my Fergie.
See my recent post, before buying one. If he won't sell you one without an iron-clad, bulletproof money back guarantee, then forget about it. It is sort of a kluge. --Tom in GV
Phil (VA)
03-07-2003 09:10:27
Zane Sherman, Talledega, AL sells it. It does work on the TO-30. Zane has a website. You can find him on the 9N,2N,8N Board on this site. Search the archives. He posted his site name again recently.
Dick Nyquist
03-12-2003 23:29:43
 Re: Re: Zang Thang in reply to Phil (VA), 03-07-2003 09:10:27
Sorry, I'm new tho this Ferguson stuff, What is a Zang Thang? What's it do and how? I've seen them mentioned several times but without a complete explanation.
Thanks
Phil (VA)
03-13-2003 08:23:54
 Re: Re: Re: Zang Thang in reply to Dick Nyquist, 03-12-2003 23:29:43
The Fergies, prior to the 35, and the Fords, prior to the 8N, do not have what is called "position control." i.e., on the tractors prior to those models the lift is either up or down. You cannot regulate it to a certain spot in between. They were set up principally to accommodate plowing and discing, etc. If you want to use a back blade at a height an inch or so off the ground to level your driveway or a bush hog four inches above the ground, you cannot easily do it with this setup. The Zane Thang referenced above, and a rival product called Fergie Positioner sold by Steven Gaunt in Australia, provide position control. They both work well, and they are priced similarly ($70-80). I have one of each on two different TO-30 tractors and I am satisfied with both of them.
