TO-20 Ignition switch
Mark
03-06-2003 19:04:09
My ignition switch for for TO-20 is shot and I need another. It has only two wire terminals and is simply an on/off switch. I notice in the wiring diagrams it shows a three terminal switch sometimes. Which one do I need for my tractor and where is an economical place to get one?
Ray,IN
03-08-2003 19:26:33
 Re: TO-20 Ignition switch in reply to Mark, 03-06-2003 19:04:09
The suppliers at the left have original replacement switches.
Rusty
03-07-2003 21:39:43
An 8n switch will work. 8N3679C
Mark
03-08-2003 08:40:53
 Re: Re: TO-20 Ignition switch in reply to Rusty, 03-07-2003 21:39:43
Thanks for the reply. Do you know if the 8N switch is the same diameter so it will work in the same hole?
Barry Reid, Stirling Ontario
03-07-2003 04:26:24
Hi Mark
I lost the keys to my TEA-20 and had to replace the ingition assembly. I went to TSC Hardware and bought a real good one , cost me $24. It was almost the same as what was on my tractor. It had 2 wires, from the time I installed it until the tractor was running agin was 15 minutes. Just my thoughts
marlowe
03-06-2003 19:35:47
if you have a 2 wire use a 2 wire.[ napa $6.00 ]
