Oil mystery solved
Thankyou Phil and Thankyou Big Dean
James, UK
03-06-2003 03:27:31
Sussed it!! The manual copy and 'llamas' article combined the answer;
We've never used the weight figure over here, we've only ever used the viscosity figure. So SAE 90 weight oil to you is between 40 and 50 SAE viscosity to us. Hence the difference in the manuals, and also hence the confusion on the oil grade.
Universal grade tractor oil over here will provide the correct viscosity and lubrication required, as will 'straight' SAE (viscosity) 40 i.e. oil with no detergent additives.
Therefore we were both/all correct in what we were saying, it was just that the methods of measuring the type/grade of oil differed.
D#mn, talk about a common language separated by 200 years and 4000 miles!!
Job done, no further comment on this - it's been done to death by us all - but thanks again, I can now sleep easily knowing my gearbox is safe.
phil fenner
03-06-2003 11:20:50
 Re: Oil mystery solved - Thankyou Phil and Thankyou Big Dean in reply to James, UK, 03-06-2003 03:27:31
James, I knew there was a translation problem somewhere. Very glad you took the trouble to solve it. Thanks.
Phil Fenner
