What should the amp guage read when tractor is running
jeff
03-05-2003 19:02:54
what should amp guage read when running?
just_joh10
03-06-2003 13:53:18
 Re: what should the amp guage read when tractor is running in reply to jeff, 03-05-2003 19:02:54
charging rate will also depend on the state of the battery, if the battery is in low state of charge the charging rate will show more on the ammeter, once it is more fully charged the rate will decrease.
Ray,IN
03-05-2003 21:00:40
As long as it regesters some charging and the battery doesn't go dead you should be fine. The rate of charge bepends upon the generators adjustable output setting and the voltage regulator condition.
jeff
03-07-2003 16:56:55
 Re: Re: what should the amp guage read when tractor is running in reply to Ray,IN, 03-05-2003 21:00:40
thanks for the help,reason i asked is guage always read a little negative ,i switched the wires on amp guage,now it reads a little positive,does this sound right?
Ray,IN
03-08-2003 19:43:49
 Re: Re: Re: what should the amp guage read when tractor is running in reply to jeff, 03-07-2003 16:56:55
Assuming your electrical system is original, battery is good, and the generator is working properly, the answer is yes. You should measure about 6.8 to 7.5 VDC at the battery(depending of state of charge and generator setting) when it's charging properly; with lights on and mid throttle.
