Zane Thang
Dave (WI)
03-03-2003 17:02:18
Do you really need a Zane Thang position controler on a TO-20? I've use a plow, blade, box and back bucket and never had a problem. Maybe being new at tractoring, I haven't noticed having a problem.
Boogity - Ohio
03-04-2003 17:37:26
 Re: Zane Thang in reply to Dave (WI), 03-03-2003 17:02:18
When you are using an implement that makes ground contact such as a plow, blade, disc-harrow, etc. you would not want to use a ZaneThang because the Ferguson System works very well a maintaining the proper depth of soil contact. But if you use a brush mower and intend to maintain a set distance from the ground to the rotating blades the Ferguson System does not work worth a darn. That's where the ZaneThang comes in very handy because it sets and maintains the precise distance off the ground based upon your initial settings.
Jeff
03-04-2003 07:05:29
Short answer: No.
You would only need one if controlling impelement height above ground were important to you.
Dave (WI)
03-04-2003 18:12:57
 Re: Re: Zane Thang in reply to Jeff, 03-04-2003 07:05:29
Thanks Boogity & Jeff. Makes more sense to me now. Some of us are so inexperienced, we don't see the forest through the trees.
