Voltage regulator
Ken in Memphis,
02-27-2003 16:02:56
This is a dumb ? but im going to ask anyway. Does the regulator need to be grounded to the tractor frame? Thanks for any help.
James, UK
02-28-2003 00:33:52
 Re: voltage regulator in reply to Ken in Memphis,Tn, 02-27-2003 16:02:56
Ken,
On the regulator there are four connections, F(ield) for the dynamo, A(ccumulator) for the battery, E(arth) and D(ynamo), so yes the regulator needs connection to Earth - which is the frame of the tractor.
I can't remember if the regulator earth is also connected to the steel frame of the regulator, but I imagine it might be.
Ken in Memphis,Tn
02-28-2003 13:06:17
 Re: Re: voltage regulator in reply to James, UK, 02-28-2003 00:33:52
Thanks James and yes the frame of the regulator is ground but it has rubber mounting sleeves where it bolts to the frame of the tractor that prevents a connection. That is why I was not sure.
